Ignition Replacement Help
Old Jun 27, 2008 | 05:55 PM
Desmare's Avatar
Car: 1986 Camaro Berlinetta
Engine: 350 Turbo
Transmission: Automatic
Axle/Gears: 4.10
I realized i posted this in the wrong section and im sorry.
I need help replacing the ignition cylinder in my 1986 Camaro Berlinetta. Its a straight column and i just cant find out how to release the old one. I was wondering if someone had like the haynes manual or something they could scan and show me or even just tell me how because i was told to take the steering wheel off and well its not comming off for me. I took the nut off inside and its just not budging.
Thank you so much everyone!
Old Jul 2, 2008 | 11:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Ignition Replacement Help
you have to use a steering wheel puller
Old Jul 4, 2008 | 08:06 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Go to Autozone and rent the steering wheel puller. Once your done just return it and they will give you your cash back 2 bolts will get screwed into the steering wheel colar and one big bolt will push on the center of the steering column shaft. The wheel will pop right off after the big bolt is turned a few rotations !
justin57
Aug 20, 2015 07:05 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
