Help w/ Hatch latch please
Old Jul 3, 2008 | 10:39 PM
1970 Buick's Avatar
Car: 1989 GTA
Hi all, I just bought my first GTA yesterday. It is an 89 with the electric hatch opener. It will not latch though. The motor works fine and so does the switch, but the actual u-shaped latch won't lock into the mechanism. The locking mechanism also works and movers freely. It seems they are just not matching up or something..Any help would be greatly appreciated! Thanks in advance, Andy
Old Jul 3, 2008 | 10:55 PM
Stephen's Avatar
Car: 87 GTA
Re: Help w/ Hatch latch please
Is the latch not closing? Is the motor moving the latch up & own? Or are they not even meeting each other to latch?
Old Jul 4, 2008 | 01:04 PM
1970 Buick's Avatar
Car: 1989 GTA
The motor is going up and down fine. I think the latch on the hatch lid just isn't meeting where it needs to hook up. I tried again today but just can't figure it out.
Old Jul 4, 2008 | 01:20 PM
fallenleader's Avatar
Car: 1984 firebird
Engine: 2.8 v6
Axle/Gears: soon: A working car.
You probably need to take that plastic panel off the *** end in your trunk, loosen the 3? bolts and slide the hatch mechanisim up.
its not hard to do at all.
after so many years of hard pounding it might have worked its way down.
Old Jul 4, 2008 | 01:50 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
heres another question. my hatch is unaligned when the motor pulls it down. i was told to loosen the bolts. and **** the motor sideways on one side. sound right????
Old Jun 29, 2009 | 09:46 PM
swashplate97's Avatar
Car: 89 Camaro 2.8 for now
Engine: 2.8
Ive got a crazy question. I just bought a 89 Camaro and didn't get any door or trunk keys. I popped the lock and when I opened the hatch and removed the tail panel in the trunk area I found an actuator/motor... how do you actuate the trunk release from inside the car? Thank you for any help you may be able to give. Jason
Old Jun 30, 2009 | 08:03 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
The release button is on my console
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
