Help my steering column is broke
Old Jul 9, 2008 | 08:57 PM
ozzman's Avatar
I am hoping someone can help me with this - I have an 88 GTA with tilt column and a digital dash. The steering wheel also has the radio controls on it. I got in my car the other day and the steering wheel moves up and down and side to side approximately 1 to 1.25 inches. The steering wheel itself is tight, but where the column adjusts appears to be where the problem is. The lock housing is also rotating slightly making it nearly impossible to use my right hand turn signal. I am going to a junk yard to try a find a new column but was wondering if anyone had encountered this before or if anyone had any suggestions. I'd rather fix my original one rather then replace it.
Thanks,
Rob
Old Jul 10, 2008 | 07:50 AM
davr89's Avatar
Car: 2004 Silverado SS
Engine: 6.0L LQ9
Axle/Gears: 4.10 AWD
Re: Help my steering column is broke
https://www.thirdgen.org/steeringcolumn
did this with my old 89rs, took me and my buddy about 4 hours to do, but that was because it was the middle of february and we were outside doing it with a small space heater in the car. jsut make sure you have the required tools to do it
(tilt steering pin remover, steering wheel puller, lock plate compressor) and the job will go by very easily.
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
