Recently Rained out and Carpet is Wet..
Old Oct 30, 2008 | 11:35 AM
fearthisinc's Avatar
Just wondering if anyone knows of any spots where water might get in on a 87 Iroc w/ t-tops. Not sure if there are any common leak areas. I havnt driven the car in a while but for the past like 2 days it rained pretty hard and when i got in the car today everythihg was fine but i reached in the back seat and grabbed someting off the floor and felt the carpet was soaked.. seems like it is only in the passenger side rear floor...
Old Oct 30, 2008 | 11:38 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Recently Rained out and Carpet is Wet..
yes, around the t-tops.
Old Oct 30, 2008 | 11:40 AM
so if this is common is there a fix for it or do i just deal with soaked carpets?
Old Oct 30, 2008 | 04:27 PM
Diengrey13's Avatar
Car: 1988 camaro iroc-z
Engine: 350 t.p.i
Axle/Gears: 12bolt/posi
Actually it is common. my first camaro was an 87 iroc -tops. You gotta remember, its a some-what old car. they probably dry out, peel off, deteriorate etc.. What i did was jus replace mine. Ive herd people use like wetherstriping gunk on it, but it never last and just looks horrible and cheap.
Old Oct 30, 2008 | 04:35 PM
89RsPower!'s Avatar
it's a very common problem, sometimes it can be fixed with weather strips if that is the problem, sometimes the body is tweaked a little which throws the alignment of the t-tops off a little and causes them to leak due to spirited driving of a weak unibody car without subframe connectors.
Bubbajones_ya
Jul 6, 2024 08:32 PM
F-body-fan
Nov 4, 2015 06:13 AM
Bob88GTA
Sep 10, 2015 09:07 PM
fasteddi
Sep 10, 2015 09:32 AM
tgp1990
Sep 4, 2015 06:24 AM
