camaro speedometer in a trans am?
Old Oct 31, 2008 | 12:08 PM
solaris_vii's Avatar
Car: 1997 z28
Engine: lt1
Transmission: t56
currently parting out some of my interior from my 85 z28, and i got a guy with an 83 trans am interested in my 145 mph speedometer. i know the dashes between the two are pretty different, but, can you just take the speedometer out of the cluster housing from the camaro and put it into the the trans am housing? i dont know if they are the same size or if it would work, so if anyone has any input lemme know. thanks
Old Nov 5, 2008 | 09:17 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: camaro speedometer in a trans am?
I'm 99% sure they're different sizes and won't swap.
Old Nov 7, 2008 | 03:07 PM
glitch666's Avatar
Car: 84 T/A
Engine: 350 carb
Respectfully, that usually means one does not know.
Has any one out there tried this swap before?? I'm almost ready to get one
of the Camaro 145's just to see if physically I can make it work. The Camaro 145 I've got my eye on ,..."This Speedometer is driven from the speedometer cable. It has an electronic speed sensor to plug into the vehicle computer if needed."...
SNAP!!! I've got a instrument cluster from a 87 Comaro (85mph though)
I'll will dig it out and see iffin the speedo will fit in one of these 84 T/A clusters!! Close enough. Yeah I'll do that tonite...if I don't go see BUCKETHEAD!!!!
Old Nov 10, 2008 | 09:16 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
No, it means exactly what it says. The firebird speedo is smaller. It may be possible to take the guts from the camaro speedo and use with the firebird gauge face, but even then you'd have to renumber the thing.
Old Nov 10, 2008 | 02:20 PM
glitch666's Avatar
Car: 84 T/A
Engine: 350 carb
Ward,
I stand corrected, you are right on the money. The larger camaro speedo's internals may very well be adapted to the "smaller firebired speedo". I played with the camaro speedo (though of the 85mph variety) thinking I would be able to get it to fit into the firebird socket by trimming the od...the trip odometer reset is even in a different location. Having to engage in truly productive activity, I opted to return to this "R&D" adventure in the future.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
