seat swap
seat swap
ok so the seats in my iroc needs to be replaced. i have a beautiful set of seats out of a 69 camaro. will these fit in my iroc? i also have a gt grant steering wheel for my car but it doesnt bolt up where my original one does. i have the thing to swap it out so it fits but i cant seem to take the old one off. is there a certain tool i need to do this? when i took the one main boldt out of the center it still wouldnt pop off. thanks
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: seat swap
The '69 seats won't bolt in without some modification to the tracks. It would be easiest to try and use your existing seat tracks with the 69 seats. To remove the steering wheel, you need a steering wheel puller (usually the same tool as a harmonic balancer puller) - it's pressed onto the steering shaft. You can buy one from autozone/o'reillys for around $15.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: seat swap
JamesC
Re: seat swap
alright thanks for the reply. ill just try and find one somewhere.i thought it was weird that it wouldnt pop off. i wasnt aware that you needed a tool. and i check out your car jamesc. its very nice. ive been thinking of painting mine the same color.
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
