STRIPPED DASH PAS SCREWS!! HELP!
Car: 88" Trans am
Engine: 350 bored. 383 Stroker Kit
Transmission: Power Glide
Axle/Gears: 4:10
Yet another question fellas. My scews in my dash pad on the underneath lip seem to rattle loose and some even fall out. the insides of the dash pad where the screws go into is stripped out and was need to know what type of thin rubber washers to use and how to fix the insides so the screws will again hold.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: STRIPPED DASH PAS SCREWS!! HELP!
Use some #10 wood screws with washers, you can paint them black and no one will notice.
Car: 88" Trans am
Axle/Gears: 4:10
are the #10 wood screw threads different or what bc the pads holes are stripped.
The screw itself is larger, should take up the slack in the current openings...just get the correct length as your old one's and you'll be ok.
Car: 88" Trans am
Axle/Gears: 4:10
hmmm.. not sure what size, its factory screws, they look like 1/2 in?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
#8 screws will probably work, mine were not stripped, but i replaced them with #8's and they fit very snug. Grad some of each and see what works.
DO NOT USE WOOD SCREWS!!!!!! they are tapered and usually have a un-threaded shaft before the head. hmmmmm that sounded bad
use sheet metal screws, im using panhead stainless screws with the matching stainless washers. I've replaces almost every screw that i even removed with stainless Phillips heads. That way i can pull most of the interior apart with a single screwdriver.
1/2" or a little longer will be fine. Most of mine are 3/4"
the factory screws have a smaller diameter, they are metric, so maybe something like a #7 of there was such a thing. A #8 is just a tad bigger and a #10 is much larger, probably too big and may require you to drill out the holes a little just to install them.
Car: 88" Trans am
Axle/Gears: 4:10
no get some #8 sheet metal screws? i would prefer some with washers and all be black...
Car: 2003 SILVERADO /86 IROC/85 S10
YOU'LL PROBABLY HAVE TO PAINT THEM, BUT I SUGGEST THAT WHATEVER YOU USE, WRAP A LITTLE TEFLON TAPE AROUND THE THREADS AND THAT SHOULD KEEP THEM FROM VIBRATING LOOSE.
Yep, the stuff is almost perfect for things like that. I hope you get it all back together and don't have to worry about screws falling in your lap anymore.
Car: 86 Trans Am
yea, you will probably to paint the screws, it hard to find black finished screws that dont cost a fortune.
Not sure how teflon tape would work, but i have no experience with that.
The biggest problem with using teflon tape for things like that is over tightening. The tape will only accept so much torque and then you are back to square one. Just tighten them snug and they should do just fine.
Car: 88" Trans am
Axle/Gears: 4:10
Alright thanks, from what ive heard here and some other friends i say i should use #8 screws for bigger diameter, and between the pad and the dash bezel i im going to put thin felt strips to have a cushion to tightin down into.
