NEED TO KNOW IF DASH'S ARE THE SAME FOR ALL FIREBIRDS??
Old Dec 27, 2008 | 08:19 PM
89firebird305's Avatar
i am replacing the dash in my 89 formula, and i found one at the junkyard in a 83/84 firebird s/e, wondering if it would be the same dash, like underneath the gauges and stuff, would all the holes and such be the same? is there a difference, i need to know before i go there and spend all that time tearing it apart. thanks.
Old Dec 28, 2008 | 07:09 PM
LIDNR2's Avatar
Car: '89 Formula 350, T-Top
Axle/Gears: Stock 3.73's
Re: NEED TO KNOW IF DASH'S ARE THE SAME FOR ALL FIREBIRDS??
Me personally, I wouldn't do it. I know our dash is electronic, with no cables. just alot of plugs.
Old Dec 28, 2008 | 07:20 PM
Stephen's Avatar
Car: 87 GTA
Are you referring to the entire dash, or just the dash PAD on top?
Old Dec 29, 2008 | 03:46 PM
yea i dont think its the same, i went to the junk yard, ripped it half apart, and compared it to a pic i had of mine, and it was different. which sucks, so i'll have to search elsewhere.
Old Dec 29, 2008 | 04:12 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
there were at least 4 dash designs for 3rd gen firebirds. They are 82-84, 85-89, 90-92, and the digital dash. Aside from the digital dash, the changes aren't huge.Each "generation" of the dash does have their own unique trim pieces. The dash pads had two versions; 82-84 and 85-92. They are fully interchangable functionally... the only difference is a double trim edge on the early dashes with a more squared off look compared to the more smooth, rounded front edge on the 85-92 dash pad.
Old Dec 29, 2008 | 06:50 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Yeah, 82-84 models were black and had that fake allen head screw design similar to the Camaros. Starting in '85 they were usually dark gray and they had a smoother looking design. Some of the '85 and '86 base Firebirds also didn't have a tachometer, they had lots of little idiot lights in the center.
Old Dec 29, 2008 | 07:05 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Plenty of the 85 and up dashes were black also, but I believe you're right in that all 82-84 dashes were black. The models that had the lights instead of full instrumentation still had the same basic dash shell, just different wiring, instrument cluster, and instrument bezel/trim.
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Vintageracer
Aug 11, 2015 08:13 PM
