replacing idiot gauge lights question
Old Jan 7, 2009 | 09:22 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
my 1987 base camaro is barebones for options
does have c&c t-tops and is a v6 multiport 5-speed
but my guages r just speed and gas
the other 3 holes r red idiot lights for oil temp and battery
i'd like actual gauges for those
i'd also like to have rpm gauge but that can wait
my question is.....
do i just need to replace those 3 gauges and replace the sensors?
and the wiring shouldn't have to change correct?
or is there something else i need to consider?
Old Jan 7, 2009 | 01:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: replacing idiot gauge lights question
You need to replace the cluster and the senders.
Old Jan 7, 2009 | 02:09 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i can replace the individual gauges cuz i tihnk tehy can be individually removed but does the connector in the back change? no right?
Old Jan 7, 2009 | 02:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You need to replace the cluster.
Old Jan 7, 2009 | 03:46 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok ill buy a whole new cluster but what about the wiring connectors they stay teh same?>
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
