door help
Old Jan 30, 2009 | 08:30 AM
BigD86z's Avatar
Car: 1986 Iroc-z
door help
About 3 months ago I broke the interior door handle in the '86 camaro. But, I was too lazy to fix it, so i just rolled down the window and opened it from the outside. Well, monday I go outside and start the get in the car and I break the exterior door handle. So, now I am having to climb out of the passenger side to get in and out of my car. I have an extra door at home for parts. How can i get this door open to fix it?
Old Jan 30, 2009 | 10:59 AM
kcb37's Avatar
Re: door help
If you have the whole inside piece the easiest would probably be to break or take out the inner door handle. I have not done this yet. But I am assuming and sure that you have to have the door panel off to get the inner handel off.
If you can cut, chip or whatever a hole through it and pull the rod connected to the handle the door will open.
Other then that your going to have to get the door panel off.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
