Door Help? -___-
Old Feb 9, 2009 | 11:39 AM
Tipsay578's Avatar
Door Help? -___-
so i left my car keys in the ignition the other day, and well a cop jimmyed my car and now i am not able to open my door. i have a 1987 camaro conv.
any help on how i should fix this? befiore i started i wanted to know if the doors are easy to take apart because i think its the hinge bar that just got out of place...
Old Feb 13, 2009 | 12:13 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Door Help? -___-
I don't know if you can get the inner door panel off if the door is stuck closed. You can get the door handle off and the latch cover off with the door closed though. That may be enough to get you out of a jamb. Once you have the trim panel off that is behind the inner door handle you may be able to jiggle the door locking rod to release it. That is probably all that is wrong. Hopefully the plastic joint that connects the lock to the rod is not broken. If so you may need to rip off the inner door panel to repair it and replace it when you're done.
Lon
Old Feb 14, 2009 | 06:55 PM
Tipsay578's Avatar
well, the door isnt completly shut i can open it from he inside the the door does open.
Old Feb 14, 2009 | 11:54 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Yeah.. not to thread jack but im having the same problem. The outer door handle broke so i took the door panel off to replace the handle.. now it wont hook up correctly.. i closed the door and now it wont open.. took it too a body shop and he got it too open.. worked for a bit.. then stopped working.. my dad tried man handling it.. broke my inside door handle and now my door doesnt work at all.. i can't even get it to open by pulling on the rods..
I think i'll have to take it to a body shop again.. but is there any suggestions on how i might be able to fix it?
Old Feb 15, 2009 | 12:17 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Then yes, take the trim panel off and see what happened. Hopefully nothing broke or bent, something just came undone. If the outside handle rod came out of the handle it may require a new retainer. If it was pulled out of the latch it probably bent the rod. Post what you find if you need more help.
And since you have the door apart lube your latch and your window tracks with some white lithium spray grease.
Old Feb 15, 2009 | 12:28 AM
Car: 86 T/A
Engine: 5.0 TPI
Is your trim panel off or on right now? If the panel is on and you are sure the door is unlocked you should be able to roll the window down and go in thru the top window opening and work the latch by hand with a long screwdriver or a thin stick or something. When you get it open and the trim panel off unhook the rod to the outside door lock if you have to. If it's not installed properly and in a bind then it will prevent the door from opening. Let us know what you find.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
