Removing shift ball on auto transmission
Old Feb 17, 2009 | 05:25 PM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Does anyone know how to release/remove the shift ball on an automatic tranny? Im trying to remove the console so I can replace the ebrake but cant seem to figure out how to disengage the ball.
Thanks in advance!!
Old Feb 17, 2009 | 05:37 PM
Stephen's Avatar
Car: 87 GTA
Re: Removing shift ball on auto transmission
Put the lever ALL THE WAY BACK, into 1st gear. Look at the front of the shift ****, down low.
There is a slot in the handle. In there, there is a small c-clip. Use a SMALL flat-bladed screwdriver to slip under it, in the slot, and pry it out.
Old Feb 17, 2009 | 05:58 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
then dont forget once you have this done to push the top button all the way down while pulling out the small clip in the center of it and rotating it to free the clip, button and spring. then pull the **** off.
Old Feb 17, 2009 | 07:35 PM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Thanks guys! I figured it out.
Old Feb 18, 2009 | 09:48 AM
Stephen's Avatar
Car: 87 GTA
Why post the same question in 2 areas?
https://www.thirdgen.org/forums/brak...ml#post4048303
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
mizz0313
Aug 12, 2015 06:45 AM
3rdgenparts
Aug 8, 2015 07:09 PM
