91 Camaro Dash
Old Feb 18, 2009 | 08:14 PM
KlawinEagle's Avatar
Car: 91 Camaro RS
Transmission: 700-R4
Axle/Gears: 373
91 Camaro Dash
I got a new Inst. Cluster, well for a salvage yard, and went to go install it. It is the exact same one that I currently have. I went to hook it up, and all the sensors read correct, except when I started the car, the Tach pegged out at idle and just sat there. Is there a fix to this, or is the cluster, well a cluster now.
Old Feb 18, 2009 | 08:19 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: 91 Camaro Dash
ive heard you might be able to fix it.. but when mine pegged out like that i bought another cluster from ebay. it worked perfectly. which tells me it was a bad tach on the old cluster.
Old Feb 20, 2009 | 07:08 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: 91 Camaro Dash
You can swap the little PC board for the tach from your old cluster into the new cluster.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Vintageracer
Aug 11, 2015 08:13 PM
