pull down hatch to manual hatch
Old Mar 2, 2009 | 04:48 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
first of all i wanna say that i searched and none of them really answered my question... i wanna know what all do i need to convert to a manual hatch system... how do i install it..... im tired of the electric one and it has gotten on my nerves.... pictures would be nice... thank you in advance....
Old Mar 3, 2009 | 02:44 AM
Darth Satanis's Avatar
Car: 86 Firebird
Engine: Buick 3.8 V6 Turbo
Transmission: 200r4
Axle/Gears: 3.42's
Re: pull down hatch to manual hatch
A friend of mine has done this to his car.
You will need both the mounting bracket and latch assembly from an 82-85 car.
Then remove the pull down assembly, and the bracket it bolts to the bracket is held in palce with 3 or 4 spot welds, Weld in the new bracket for the manual assembly, adjust the latch assembly with the hatch closed (preferably with a buddy on the outside to help you) and your done, all in all takes about a 1/2 hour.
Old Mar 3, 2009 | 06:13 AM
88fastgta's Avatar
thanks man so all i need is this... this is from a 82.-85 car.... am i missing a piece or is this it....
Old Mar 3, 2009 | 06:29 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Nope, you still need the support bracket from the car that came from.....it's welded in place.
You can't just bolt that in place of the electric latch.......it won't work.
Old Mar 3, 2009 | 10:21 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I've welded a few of the pull down assemblies permanantly in the down position so that they were like a fixed latch. That way there were no pieces to buy. And no welding on the body.
Old Mar 4, 2009 | 11:17 PM
Car: 86 Firebird
Transmission: 200r4
Axle/Gears: 3.42's
You will also need the part that that piece bolts onto, which is what is spot welded to the body.
Vintageracer
Jan 10, 2020 05:33 PM
Uglybronco
South Central
Oct 25, 2015 09:22 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
zayne0
Aug 24, 2015 07:22 PM
madsv1000
Aug 20, 2015 06:45 AM
