Noise reduction panel?
Old Mar 10, 2009 | 10:41 AM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
Om my 89 service manual, they mention a noise reduction panel between the water panel and the door panel. Was this effectively mounted? What was the material used, do someone has a sketch or picture where I can see the dimensions?
I do not want to stop the rattles this way, but as I am rebuilding my door panels I want to make a proper build, may diminish the road noise.
Old Mar 10, 2009 | 11:28 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Re: Noise reduction panel?
Is this the rubber strip along the bottom? I have a '91, I only remember, the clear plastic that covered most of the door, a black rubber strip at the bottom, then the cardboard door panel.
Old Mar 11, 2009 | 07:49 PM
loopingz's Avatar
That is the classic setup but in my book they show an additional layer, a bit smaller than the plastic one, supposed to be sticky to the plastic one.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
sjorgens
Oct 1, 2015 07:54 PM
kkirch15
Sep 30, 2015 04:44 PM
formula00ra
Sep 28, 2015 11:50 AM
