LED's in Instrument-Panel
Old Apr 13, 2009 | 06:35 PM
oxide2007's Avatar
Car: 1992 RS
Engine: 5.0 305
Transmission: 5-
Dear Members,
I'm installing LED's in my '92 RS I.P.
Basically my steps were:
A) Remove IP and lightbulbs
B) Break the halogen light and pull it out, this may not have been necessary but I didn't know how else to get the light out.
C) Solder in LED's
The LED's I'm using are superflux 4-chip blue from Oznium.com.
Here's the solder and silicon work, haha not the prettiest, but i'll post more pics of when its actually installed too.
Old Apr 14, 2009 | 11:03 AM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Re: LED's in Instrument-Panel
You could have gone to www.superbrightleds.com and purchased the replacement bulb without doing an work. The old bulbs just pull out of the socket and you reinstall the new bulbs, they are 194's. I hope this makes you job easier.
Eric
Old Apr 14, 2009 | 11:40 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Some are 194's some are 74's
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Also note, most LED bulbs have thicker or longer housings so be sure to measure stock vs superbrightleds sizes to ensure a proper fit.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
