Which To Use
Old Apr 17, 2009 | 10:28 PM
84TransAm383's Avatar
Which To Use
I have a three pod pillar and gona run the guages but not sure which ones. I got a trans temp because im running a cooler w/fan not thru the rad tho and no temp switch. What should the others be. Oil pressure,water temp, volts, oil temp. Any suggestions. (Not for look but more for vehicle monitoring)
