steering column trouble
Old Jun 27, 2009 | 02:58 PM
leek157's Avatar
Car: 95 SHO. 87 IROC red 69 Vette blue
Engine: 3.0 Yamahammer.5.7 TPI L98, 350
Transmission: mtx4 ,700r4, 4speed,
Axle/Gears: 3.27, 3.73
I am in the process of swapping out columns and I cannot remove that cable on the top left side of the column I think it is the park neutral saftey switch, do I just pry it out or is there a clip
Old Jun 29, 2009 | 02:01 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: steering column trouble
You could pry at it,...... There's a black plastic clip holding the cable in place in the white plastic housing.
If you have good access to the column end of the cable - you could also remove the tiny philips head screws and remove the plastic and the cable from the column without prying !
Ed1LE
Sep 30, 2018 09:14 AM
mrbird
Oct 20, 2015 03:43 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
