Help with swapping berlinetta parts to z28 car
Old Jul 5, 2009 | 09:05 PM
Silky_Camaro's Avatar
Car: 1983 Camaro Z28 Crossfire injection
Engine: 305 5.0 litre crossfire
Axle/Gears: not sure, but it has POSI
HI well to start off. I have a 1983 Z28. TBI crossfire injection 305 v8. I am buying another camaro as a parts car. 1985 berlinetta with a digital dash. Is it possible to swap out my original gauge cluster for the digital cluster in the berlinetta? Also would the dashboard from the berlinetta have to be placed into my z28? and if so would anyone know if that all would fit? my gauge cluster is the normal camaro cluster with the MPH reading to 85 top. I know for a fact that my cluster pulls directly out and has electrical contacts for all the gauges but the only gauge that is cable driven is the speedometer.. So that being said would this other digital dash need converting and if so would the parts from the berlinetta as far as wiring harness/etc work for my car or would i have to buy some stuff? Im hoping this would work because my normal MPH gauge doesnt work. i broke the needle off and had no luck soldering/glueing back. hopefully someone knows if my original dash pad/cap would fit on the berlinetta dash or no? im asking because im buying this car tmrw and depending on how much parts i can use, i wont buy it. parts car does run and drive.
Last edited by Silky_Camaro; Jul 5, 2009 at 09:18 PM. Reason: typo on the year of the berlinetta, 1985 not 83
Old Jul 5, 2009 | 09:30 PM
DANWOOD's Avatar
Car: 85 Camaro
Engine: 2.8 ltr
Transmission: 5 Speed
Axle/Gears: ?
Re: Help with swapping berlinetta parts to z28 car
all should fit the cars are all built the same, yiu will have to use wiring harness frome doner car
midge54
Jan 29, 2017 07:00 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
