Manual mirror help!
Old Jul 19, 2009 | 02:39 PM
blakbird89's Avatar
Car: "Nina" 1988 Trans Am GTA
Engine: TPI 305 V8
Manual mirror help!
Does anyone know how to attach the side view toggle switch into the little plastic cover that goes on the door panel? It seems to sit in a small groove, but I just can't figure out how to lock it in place.
Thanks,
Jack
Old Aug 3, 2009 | 02:06 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
Re: Manual mirror help!
When it sits in the slot there a hole that goes though the *** side of thecontroller assembly through the plastic.. There is a half circle clip w/little stright ends facing the center of the C clip that hook in each side and hold cable in place. I have lost mine several times and have found if you take a med. size cotter pin and drill the plastic on the sides large enough for the cotter pin to slide through the assembly it works fine. Holds everything in place nice and tight.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
