seat belt options for 87 iroc
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
Re: seat belt options for 87 iroc
83-92 fronts will work or 4th gen belts will work up front with an '82 door sill, there's a write up in the tech articles.since your car is an '87 it only has lap belts in the rear, I've used late 90's receivers from a cavalier in my car but most likely a lot of gm receivers will work as long as they are the same style and length. I never changed out the actual belts in the rear but my guess is there are probably similar gm lap belts on some 88 and earlier cars.
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i mean fronts the rears are fine sorry. i found an 02 trans am and just wanted to make sure thell fit my 87 before i grab them
Engine: 5.0 TPI
yeah they'll work but keep in mind they will not have the lower retractors on the door sill here's the tech article, it's a fairly easy install. https://www.thirdgen.org/4thgenbelts
1992 Trans Am
May 10, 2023 07:19 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
mustangman65_79
Aug 11, 2015 03:17 PM
