84-91 Dash Conversion
Old Jul 28, 2009 | 04:07 PM
jallen100's Avatar
Car: 84 Camaro
I know this has probably been covered somewhere else but I was unable to find my issue specifically. I came across a 91 Z28 dash, priced very good and need to know if it is a direct bolt and wiring hook up in for my 84 Camaro. I do not have digital gauges.
Old Jul 28, 2009 | 06:14 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: 84-91 Dash Conversion
Everything will wire up , but you need to convert your VSS to electric so that you will have a working speedo. Easy swap.
Old Jul 29, 2009 | 11:30 PM
will_b72's Avatar
Car: 1988 IROC Z28
Engine: 305 TBI
So If I were to take the 91 dash out of my parts car and put it in my 88 iroc. All I would have to change is the VSS?? What about the steering column and the guage cluster? Will it work with the harness in the 88?
Vintageracer
Sep 24, 2017 12:34 PM
2012sergen11
Oct 13, 2015 07:38 PM
loud91rs
Oct 5, 2015 10:05 PM
rusty vango
Sep 29, 2015 02:44 PM
mfp189
Sep 27, 2015 09:25 AM
