rear seat bracket
Old Aug 31, 2009 | 10:35 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
rear seat bracket
Has anyone else had problems with the square nut on the back of the bracket that holds the back seat(the part you seat on) break off? so now it just spins when I try to tighten down the bolt! it started on one side and now the other side in broke too! its a pain in the @ss to get to!! :gocrazy
Old Sep 2, 2009 | 10:28 PM
Car: 89 camaro
Engine: 383
Re: rear seat bracket
nobody else has had this happen??
Old Sep 3, 2009 | 12:21 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
no. You say its the seat itself? that one single bolt that holds it down?...
Old Sep 3, 2009 | 12:22 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
I am pretty sure that nut is welded on.. How the f did you get it off?
Old Sep 3, 2009 | 12:25 AM
Car: 89 camaro
Engine: 383
it just the part the bolt theads into! It might of been welded! when I went to tighten the the bolt the square nut on the back side started spinning with it! Im going to look at it some more and try to weld it back but its in a tight place!
I was just wondering if this was a common problem..i guess not!
Old Sep 3, 2009 | 09:41 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
One of mine came loose. I am going to weld it back once I get my floors done. I have bigger problems to attend to with my floors.
Old Sep 3, 2009 | 10:56 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Single mounting bolt goes into this bracket.....for holding bottom rear seats in place.
Old Sep 3, 2009 | 11:10 AM
Car: 89 camaro
Engine: 383
yes..thats the bracket//if you put your finger up in side there you will feel the square nut that the bolt theads into! its a pita to get to!
Old Sep 3, 2009 | 10:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
One of mine broke loose as well - I just got a friend to help me - one of use held the nut up in there with fingertips, while to other got it started, then we squeezed a set of needle nose vice grips in there to hold it. You have to have an extra set of hands, and both working from opposite sides, and both have to push back on the seat foam to hold the seat out of the way to get in there. A little patience, alot of cussing, and you'll get it (have a cold one handy as a reward to keep you focused).
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
z28addict8490
Aug 7, 2015 08:48 PM
