Friends 84 Trans am steering wheel problem
Old Sep 7, 2009 | 07:33 PM
Goldenbullet44's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 smallblock aftermarket cam
Transmission: Borg warner T-5
My friend has a 1984 pontiac trans am and he has a problem with the steering wheel its loose and wiggles around and he cant use his acc because of it i was wondering if or is there a way to tighten or do you have to replace something not familiar with columns anything would help for info.
Old Sep 9, 2009 | 04:55 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Friends 84 Trans am steering wheel problem
Yes under the horn button there is a big nut. Tighten that.
Old Sep 9, 2009 | 11:39 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Yikes!!
Seriously, the columns become loose because of 4 bolts that are located beneath the locking plate, under the signal canceling cam, below the housing, in the bowl ......
You need special tools and experience to fix it. Tell your friend to take it to a shop because if he doesn't know what's wrong with it he will just hurt it worse trying to work on it.
Or he can bring it by and I will fix it up for him.
Old Sep 10, 2009 | 07:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old Feb 28, 2011 | 06:08 AM
flyinc's Avatar
Car: 1984 Pontiac Trans Am
Engine: V8
Transmission: 700R4 with shift kit
Thanks for the great instructions and pics! They really helped me out this weekend!
Jorlain
Aug 24, 2022 05:11 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
