nce between a Camaro and Firebird Dash Pad
Old Oct 7, 2009 | 12:50 PM
FED 387's Avatar
Anybody know FOR SURE what the difference is between a Camaro and Firebird dash pad is???? I've been told they are not the same size!!! True ???--- Will a Fbird pad fit in a Camaro??? Do not care about speaker holes or any defroster vents will it fit in the place of a Camaro dash or will it not fit??? thanx fed387
Old Oct 8, 2009 | 08:25 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: nce between a Camaro and Firebird Dash Pad
Other than the speaker grilles and defroster vents, a Camaro dash has a little portion cut out at the leading edge of the pad to clear the center heater vents in the dash. A firebird one doesn't; it is straight all the way across.
I would imagine you can interchange them, but I don't know if it would look right, and not sure how well a Firebird one would clear those center vents.
Never hears anythng about them being different sizes.
Old Oct 8, 2009 | 10:01 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
The firebird dashpad is also about 2 inch shorter in width and the holes for the screws do not match.
Old Oct 9, 2009 | 02:52 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
it is a difference size, will leave a nice gap between the dash and the windsheild, and the holes will not line up. Been there, tried it.
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Vintageracer
Aug 11, 2015 08:13 PM
