Turning on dash lights makes fuel gauge drop
Old Oct 11, 2009 | 03:01 PM
thecraze's Avatar
I have an 86 Camaro Sports Coupe. The fuel gauge already bounces up and down, but when I turn on the dash lights, the fuel gauge drops to Empty. Has anyone else had this problem?
Old Oct 11, 2009 | 03:53 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: Turning on dash lights makes fuel gauge drop
I had a similiar problem a couple rears back... When I turned the gauge lights on the gas gauge and the oil pressure gauge would drop to 0 and the speedo and odometer would freeze in place... Only thing that would work was the tac'... Have you removed your gauge cluster at all?? It could be a bad connection were the circuit board of the cluster meets the pins... The littlest offset can screw up the whole thing...
Old Oct 11, 2009 | 03:56 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
...wait just saw you have an 86, what I saids not gonna work for you... haha my bad... sounds like it could be a bad ground somewhere...
Old Oct 12, 2009 | 07:18 AM
thecraze's Avatar
I'll pull the cluster and check. BTW the previous owner installed an aftermarket needle temp/volt/oil gauge.
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
Kaweh
Aug 9, 2015 02:54 PM
apie2546
Aug 8, 2015 07:12 AM
