How to disconect the cable behind the odometer?
Old Oct 11, 2009 | 09:17 PM
Hooyah's Avatar
the front panel on my 89 iroc, behind the gauges has a cable that I cant take off, how do i take it off. I started with changing the steering column and now i said hell with it my gauges have been tripn out so i started taking them apart. i got to the part where there is a cable behind the odometer anyone know how to disconnect?
Old Oct 12, 2009 | 11:01 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: How to disconect the cable behind the odometer?
The speedometer cable is held on by a clip.To detach it you must press it inward toward the cluster and it should release the cable.Somtimes it can be tricky.I usually use my finger to pop the clip but other use a flat bladed screwdriver.Hope this helps you out
Old Oct 12, 2009 | 03:58 PM
holeshotkid's Avatar
Sometimes you also have to push the cable towards the cluster as you push the retaining clip before it will release the cable. The retaining clip is on the cluster itself.
Old Oct 17, 2009 | 12:34 AM
Hooyah's Avatar
thanks guys i got it, it was simple just needed some direction thanks again.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
