can somebody help me with my steering column
Old Oct 12, 2009 | 05:42 PM
poppa843's Avatar
i just got my replacement column in and i cant get the old one out. i remover the two nuts from under the dash and the three screws connecting to firewall. and also the bolt and nut the connect to the bottom of the column under the hood. the column will drop down and slide back a little but will not come loose. am i missing something that connects it? i havent driven my car for a week and need it fixed asap
Old Oct 12, 2009 | 06:29 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: can somebody help me with my steering column
might hafta tap that shaft under the hood where the bolt was with a hammer, they sometimes get stuck.
Old Oct 13, 2009 | 08:39 AM
poppa843's Avatar
I finally got it off. I had lock my legs against the floor and pull way harder than I though I did. When it came loose it smahed my finger against the bottom of the dash and cracked the fingernail. Now I'm headed to get a key made with the right vats chip. Finger is still purple but its better than paying the shop two hours worth of labor. Thanks for the help
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
