A perfect bolt-in solution for more headroom!
Old Nov 15, 2009 | 04:56 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I'm glad some of you havent had head room issues, but I'm not sure why you're in here then. This thread is pretty much only for people that need more headroom and not for people to brag about how they are fine in the headroom department. thanks.
Over the weekend I put a seat track from a Pontiac Fiero on my drivers seat. It doesn't allow any more rearward adjustability, and you lose your lumbar adjustment, but it lowers the seat about an inch closer to the floor. MAN what a difference it makes!! I got mine from www.thefierofactory.com for about $25. It bolted right to the seat, and then right to the car with no mods/grinding/nothing needed. Best $25 I've spent! WAY worth it.
You can compare the two seats and see the driver side sits lower. From what I've seen, you CAN do the passnger side, but it takes a little bit of massaging. Exactly what is needed, I don't know since I didnt do the passenger side.
Old Nov 15, 2009 | 05:55 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: A perfect bolt-in solution for more headroom!
I am gonna have to do that because some times i give my cousin a ride and he has to take off the t top for he won't hit
Old Nov 15, 2009 | 06:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Who cares about the passenger !
JamesC
Old Nov 15, 2009 | 07:44 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Thats true do you know up to which height some one could be in this cars since i am 6ft and almost hit the top maybe in a bump i will hit
Old Nov 15, 2009 | 07:54 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
didnt think my seat could get any lower!
Old Nov 15, 2009 | 08:44 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
just fyi the drivers side seat is adjustable up and down from the factory...
Old Nov 15, 2009 | 08:47 PM
Stephen's Avatar
Car: 87 GTA
I'm 6' 5" and never had a head clearance problem in any of my hardtop 3rd gens.
But after putting in 4th gen seats (DIRECT bolt in), they sit an inch or two lower, way more comfortable & well worth the cost of buying them. Simple cloth seats, no leather, power or lumbar crap here. I haven't had any desire to adjust them since day 1 (of having them) so I've had NO need for power seats anyways.
Old Nov 17, 2009 | 07:00 AM
Car: 89 formula 350
I like to sit with my seat straight up and it felt cramped. The Fiero seat track makes my interior feel like a new car, and I no longer hit the roof with a helmet on now. I know one pretty tall guy that has head room problems in his convertible and one guy that does road racing that has to sit in an unnatural position so his helmet wont hit the ceiling....hopefully this will help them.
Old Nov 17, 2009 | 12:15 PM
Guest
Guest
Posts: n/a
Take the head liner out.....not needed and less weight.....
-just sayen
Old Nov 17, 2009 | 04:25 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
This is definitely good to know for someone needing just a little bit extra easily...easily being the key there. Sure you can cut/drop/weld things to lower it, but a simple bolt in for an inch or so is awesome.
Old Nov 17, 2009 | 04:38 PM
Shadow Z's Avatar
Car: Lots of 'em
Holy.... Didn't know we had any giants here on TGO. I thought I was a decent sized guy at over 6'0" and about 190 pounds.
Old Nov 17, 2009 | 05:29 PM
Stephen's Avatar
Car: 87 GTA
I was sharing my info, to point out that 4th seat swaps not only are a much more comfortable seat, but sit lower, providing headroom as well.
I've got 5" on you, but only 10 lbs heavier....
When my GTA was sitting on stock springs, the roof basically was level with the middle of my abdomen, just above my belly button. Now it's about 2" lower, on the weight jacks.
Yes, getting in the car is like me folding in half.
Old Nov 17, 2009 | 08:34 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I am 6' 2" and weigh and 17yrs old thats why i was asking since i may grow a bit i never know
Old Nov 17, 2009 | 08:57 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
how?
Old Nov 17, 2009 | 09:09 PM
JamesC's Avatar
Originally Posted by RED_DRAGON_85
how?
Some have a six-way electric track.
JamesC
Old Nov 18, 2009 | 02:00 AM
dasferret's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock open 2.73's
I've never been worried bout head room in my 92. I'm 6'6" and installed dodge stealth seats and raised the front of the seats 2 inches. It helps that I have no back seat and have the back reclined alot. Feels perfect for me. And to install the seats, I just took a peice of uni-strut, drilled holes to mount it to the old mounting bolts and the used spring nuts to bolt down new seats. Wanted stealth seats cuz they were 6 way manuals with decent side bolstering and not broken like my originals
Old Nov 18, 2009 | 09:59 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
see, ive got one way manual seats lol...
actually, in the 03 10th anniversary cobras, there was an option for air inflatable side bolsters and thigh bolsters, along with the normally 6 way adjustable seats
thats some slick stuff if you ask me
Old Nov 18, 2009 | 10:09 AM
JamesC's Avatar
Something similar was available in thirdgens. My L/S Conteur seats are equipped with mechanical thigh, seat, lumbar, and seat back adjusts--as well as sitting on a six-way electrical track. Sorry, .
JamesC
Old Nov 19, 2009 | 12:16 PM
HCR13's Avatar
Car: 1987 Trans Am
how?
check on the front of your driver's seat. There should be 2 levers one for forward-backward movement of the seat, and one for the up and down movement of the seat. These are not the recline levers...
Old Nov 19, 2009 | 01:22 PM
JamesC's Avatar
The Camaro only has a single mechanical lever which controls the front-to-back movement.
JamesC
Old Nov 19, 2009 | 10:57 PM
Shadow Z's Avatar
Car: Lots of 'em
4 inches, if we must get technical.
Old Nov 25, 2009 | 02:07 PM
corlando52's Avatar
Car: 1984 Firebird SE
Engine: 2.8 L
Transmission: Automatic
Hi! Great find! What year Firebird did you do this convert in? Do you know if it will work with 1982 PMD seats?
Chris
Old Nov 25, 2009 | 07:53 PM
Car: 89 formula 350
the seat tracks are out of any year fiero. My car is an 89 but I would assume this should work for any 3rdgen
Old Nov 28, 2009 | 08:22 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
im 6' 4" and i dont have any head clearance issues in my hardtop GTA
Old Nov 28, 2009 | 11:34 PM
Car: 89 formula 350
well im glad
Old Nov 29, 2009 | 03:55 AM
Shadow Z's Avatar
Car: Lots of 'em
I'm just going to put that quote there, for future reference. You're welcome Justin.
Old Nov 29, 2009 | 08:25 AM
Car: 89 formula 350
Thanks. Added to first post.
Old Nov 29, 2009 | 11:21 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Wouldn't lowering a body of roughly 200lbs (my weight) make the car handle better since YOUR weight sits lower? (another advantage maybe?)
Old Nov 29, 2009 | 06:37 PM
Car: 89 formula 350
I doubt it would be noticeable lol
Old Nov 29, 2009 | 09:30 PM
Probably not lol.. Oh well, but I guess every little bit counts!
armybyrd
Sep 28, 2023 12:16 AM
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
