Remove Radio/Bezel Bolt cover by dash?
Old Dec 7, 2009 | 02:12 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I have a 1992 camaro is the lower right of the dash suppose to cover the upper right hand bolt of the bezel for radio/heater? It wasn't like that in my 86. If so how do i remove it to get to the bolt?
Old Dec 7, 2009 | 03:20 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: Remove Radio/Bezel Bolt cover by dash?
My 91 is the same way. You have to remove the piece over your legs to get to it. I left it out to make it easier to get to next time. Your 86 might have been different because of the different setup with the gausges.
Old Dec 7, 2009 | 10:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Man did you have me confused on this one!
You typed "upper right" of the radio bezel - you mean the upper left! Had me going there for a minute!
Yes, the dash covers this. BUT - if I remember correctly, that upper left bolt is one of the fake ones - take out the rest, and gently pull out towards the right, and it should slide out - then you should see behind that it is actually a very short bolt that really doesn't attach to anything. BUT BE VERY GENTLE just in case I am remembering wrong!
Old Dec 8, 2009 | 11:55 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
oooops.....you are right i said the wrong thing . Thanks for the info i will check it out.
Old Dec 21, 2009 | 08:17 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
hes right, that screw or bolt is fake, just remove the other 3 and it should slid out
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
