Tilt steering
Old Jan 3, 2010 | 04:48 PM
pgmonster's Avatar
Car: Firebird Pro/Am
Engine: 5.0 TBI
Tilt steering
i am stuck i took apart my tilt steering column b/c it was loose but when i was tighning the bolts i was pushing on the middle shaft and then it fell off it has like a yellowish ball at the end of it and i cannot figure out how to put it back on. can anybody help me?
Old Jan 3, 2010 | 06:32 PM
Drew's Avatar
Re: Tilt steering
What year car? If you do a search on here you can find lots of pics of disassembled columns, and exploded diagrams. 82-89 are all pretty much the same, if you ignore VATS. 90-92 have a few more pieces for the airbag. The part you're dealing with should be the same for all the tilt columns.
Check out https://www.thirdgen.org/forums/inte...eel-grant.html
It sounds like you're saying 56 pulled apart from 57, 58, and 59? If it pulled apart, it should go back together.
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
