Anyone remove the heater box behind the dash?
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I have my dash out and everything is pretty much gone. The only thing left is the main heater box on the pass side. I already pulled the heater core out but is there a way to take the whole large box out without removing the engine compartment heater box?
This is a factory heat only car.
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Re: Anyone remove the heater box behind the dash?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
No - You have to remove the engine bay box. Once the engine bay box is removed,....... You will expose the bolt that is hidden and holds the interior heater core box in place.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Okay, thanks. I'll leave it. I gutted everything else.
