removing auto shifter to install new shifter boot
Old Jan 18, 2010 | 11:07 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
As the title says for the life of me i cannot figure out how to remove the auto shifter **** to replace my torn shifter boot on my 88 TA. Any help?
Old Jan 19, 2010 | 11:06 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Re: removing auto shifter to install new shifter boot
There is a metal clip that holds it in place on the front. Just use needle nose pliers to pull it out. Now the handle will come right off.
OK cleaned up my horrible blackberry typos.
Old Jan 19, 2010 | 11:18 AM
mikeiaz's Avatar
It is easier if you move the shifter handle back all the way, look on the front side of the **** toward the lower part and you should see the retainer clip he is referring to.
Old Jan 19, 2010 | 12:49 PM
Engine: Vortec 357
Thanks for the imput guys, ill check it out this weekend. I cant find a gm repair manual here at the shop so i didnt know where else to look.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Sep 7, 2015 01:37 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
