Can you dye leather seats
Old Jan 19, 2010 | 11:04 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I have a grey set of 4th gen leather seats. Is there a way to change the color of the leather?
Old Jan 20, 2010 | 01:03 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: Can you dye leather seats
http://www.leatherworldtech.com/
try that
Old Mar 19, 2010 | 08:55 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Yes you can. I'm in the process now. I bought 'Leatherique' cleaner and conditioner (http://leatherique.com/) and treated the seats. I just started my first seat tonight with 'Zelikovitz' dye ( http://zelikovitz.com/ ).
I have an 87 Iroc that I will be putting 97 seats into. They are currently gray and I will be making them black. So far, the one coat in a small section looks excellent and it completely covered the gray color. The black is a nice dark, rich color. Photos to follow, but to answer your question; yes! Go for it! Also, I bought both of the products on Ebay and saved about $30 bucks.
Old Mar 21, 2010 | 03:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I dyed mine over 10 years ago with SEM dye.
Old Apr 13, 2010 | 08:08 AM
Jim the Nomad's Avatar
Car: 2004 GTO
Engine: 5.7
I managed to get a hold of a decent set of the trans am door panels (GTA/TTA style, I think... the nice ones, anyways...), and they are tan.
The panels I can recover and what not, but the door pulls/armrests are a different story...
Will these types of leather dyes work for the door pulls/armrests?
Old Apr 13, 2010 | 09:00 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I had OEM leather and wanted black. I thought of dying them but was scared of what might happen if on a 80 plus degree day. So I went with a recover. That way I don't have to replace anyone's clothes and I don't have to worry about wear marks.
Old Apr 19, 2010 | 09:36 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Transmission: TH400 and 6 speed
Axle/Gears: 12 bolt 4.11 and posi 3.73
I work in auto upholstery and have used Sem vinyl dye on vinyl with success but leather is a little tricky because of the oil in it. Go very slow in its application in very light coats. It will take more time but the slower the better. The leather must be cleaned using first soap and water then acrylic lacquer thinner to strip the oils in the soap and leather off. Use the acrylic lacquer thinner very sparingly, too much will melt the grain of the leather. Also use gloves and ventilation with acetone as well as avoid smoking around it for it is extremely flammable so heat sources must be removed! But nothing will beat having them recovered so it is only recommended for color matching (SEM vinyl dye) a faded panel on a seat as apposed to a full seat. Be sure to use SEM only, it is the best.
Eric-86sc
Feb 25, 2016 09:02 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
kitt23
Sep 26, 2015 07:48 PM
