How do i remove gague cluster from my car?
Old Jan 26, 2010 | 01:12 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Hi, Ive been searching for a bit on how to remove the gague cluster from my 91 camaro and havent really found much. I have found it for 82 -89 but not for 90-92 so if anyboy has taken theres out or knows a link to a how to on the forum please help... Im wanting to take mine out so i can install new LEDs and white face gagues. Thanks
Old Jan 26, 2010 | 04:32 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: How do i remove gague cluster from my car?
Working from memory here:
1-Remove the lower cover under the steering column. Its 3 Torx screws, a T25 I think.
2-Remove the cigarette lighter and headlight *****.
3-Remove the 2 screws on the bottom and 3(2?) on the top of the gauge trim bezel, 7MM or 8MM I think they are.
4-If you haven't had to already, tilt the wheel all the way down. Pull gently on the gauge trim bezel until the clips release. Then just work it around till you can pull it out. Usually I pull it down and then tilt the top forward till it will clear my steering wheel.
5- Remove the 2 screws on the bottom and 3 screws on top. They should be the same size as the screws you removed in Step 3.
6-Gently pull the gauges towards you to disconnect them from the electrical connections in back and remove the same way you pulled the trim bezel out.
7-To remove the clear cover over the gauges, you'll need a small Torx driver. I think its a T5 or T10.
8-As they say in the manuals, installation is the reverse of removal
Old Jan 26, 2010 | 05:33 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
just did this yesterday lol. hes right ^^
keep a 7mm in handy because almost all of em are that size.
all it is it layer after layer of bolts to take off and itll come right out, i found it very helpful to un screw my tilt lever out as well to take some of the pieces in and out.
oh yea i dont remember if it was stated but youll also have to pull off all the instrument needles if your changing to a white faced guage just a heads up...be gentle with them!!!!
Old Jan 26, 2010 | 05:55 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Yes, be VERY gentle with them and be careful putting them back in. I messed up my temp gauge pulling the needle off and putting it back on. I think I got it in the wrong position cause it doesn't seem to read right anymore.
Good idea on the tilt lever, I didn't realize it unscrewed and it definitely gets in the way.
Old Jan 26, 2010 | 09:58 PM
Engine: 383 stroker
thanks guys this info help alot!!!!!!!!!!!
TheExaminer
Aug 26, 2015 04:59 PM
NBrehm
Aug 25, 2015 11:49 PM
kyleb24
Aug 15, 2015 08:24 AM
fonzie85
Aug 13, 2015 11:50 AM
3rdgenparts
Aug 8, 2015 07:09 PM
