Steering Wheel Loose Problem
Old Feb 7, 2010 | 02:45 PM
david_beast's Avatar
Car: 1985 Trans Am
Engine: 350 Small Block
Hey guys,i have an 85' trans am and my steering is getting real loose but i dont know how to take it out and tighten the screws,can somebody give me instructinos to do it??Pics would Help!!
Thanks!
Old Feb 7, 2010 | 02:53 PM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
Re: Steering Wheel Loose Problem
Ah the dreaded loose 3 bolts. Same thing happened in my 88 camaro. Its not hard to do but does take a couple special tools. It happens to almost all old GM cars eventually . I know there is a how to around here but not sure where it is .
Old Feb 7, 2010 | 04:52 PM
Drew's Avatar
Do a search... There is a tech article, there are exploded diagrams, and step by step illustrated walk throughs. You just need to make an effort to find them.
Search 'loose column' or 'column rebuild' and you'll find more info then you need.
Old Feb 8, 2010 | 04:29 AM
LTL_DMON's Avatar
Car: 1986 Trans AM
Hope this helps...
https://www.thirdgen.org/steeringcolumn
Old Feb 8, 2010 | 08:37 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
well, is it your column or just the steering wheel? I've had steering wheels themselves loosen up too. If that's the case, it's a piece of cake. Pop off your horn button, pull off the lock ring, then tighten the nut, reinstall the lock ring, and put your horn button back on.
If it's your column at the tilt joint, then yeah... time to follow that tech article. That job is a pain in the ***, but it's not particularly difficult. Just take pics along the way so that you can put everything back together correctly and you'll be fine.
Old Feb 8, 2010 | 08:58 AM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
Are aftermarket wheels supposed to have a lock ring too? The nut for my grant steering wheel keeps backing off.
Old Feb 8, 2010 | 02:02 PM
Jim85IROC's Avatar
The OEM nut and locking ring are used with the Grant wheels, so yes! Never install any steering wheel without that locking ring. If that nut backs itself all the way off, you'll get a face full of steering wheel right before you get killed.
I've also found that the OEM nut tends to back off with the Grant wheels. A small dab of loctite or a lock washer will fix the problem.
Old Feb 8, 2010 | 11:43 PM
xbox07's Avatar
Car: 86' Z28
That would make since, sorry i wasn't thinking and i didn't put the wheel on. Guess i'll go look around for a lock ring and some loctite.
Old Feb 10, 2010 | 09:26 PM
Car: 1985 Trans Am
Thank you guys,i mite as well just go to the shop and fix it with less hassle
Old Feb 11, 2010 | 07:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep. Mine got so loose on a roadtrip that I had to stop at a mom and pop shop and beg for a socket and ratchet. Even with the lock ring, which I added, the nut still loosens up some.
JamesC
Old Feb 11, 2010 | 09:47 AM
xbox07's Avatar
Car: 86' Z28
JamesC
I borrowed the nut from a late model s10 and the wheel seemed alot tighter than i could ever get it with the first nut.
BlueIroc-Z
Jun 9, 2019 03:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
