adding power door locks
Old Feb 25, 2010 | 01:59 AM
onesmartidiot's Avatar
Car: 85 marrow z28, 88 thunderbird 5.0
Engine: 305 4bbl, 302 cobra efi
Transmission: 700r4, aod
Axle/Gears: the crappy one
I would like to add the power door lock function to my car while I have the door panels off. (the top plastic trim ripped out from the cardboard)
Outside of the switches, the new plastic surround, and the actuators, what wires will i need to run to make it work? Or did GM leave the wires in there for the option?
Old Feb 27, 2010 | 09:20 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: adding power door locks
grab a whole harness, its all plug and play, thats what I did
Old Feb 28, 2010 | 01:56 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
GM did not leave the wiring. But..they did leave the connector for the power windows/locks. Go to a local wrecking yard and pull the dash off and loosen the dash assembly and pull it foreward and the window/lock harness runs there. Trace it to the driver kick panal and take the relay and pull the wiring from the doors and get the switches as well. Remember the relay is the ground on some years., so make sure you screw it down under the kick panal. It's an extremely easy sway-in. I did it and hooked up keyless entry alarm to it.
BTW: You might want to bring a battery to the wrecking yard to ensure that the actuators aren't weak and that they fully lock/unlock with one button push. Also a drill too drill out the actuator rivets.
Old Feb 28, 2010 | 04:44 PM
Chevy8588's Avatar
its all plug 'n' play
Old Feb 28, 2010 | 04:55 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Most of these lock motors are worn out and garbage. Save yourself the hassle and buy a $20 kit that comes with the harness , remote switch and all accessories to hook it up. Easy as pie. You can then unlock your car while walking towards it.
Old May 7, 2010 | 06:18 PM
oscar246's Avatar
where can i buy one?
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
