4th gen seats. It really is as easy as it sounds
Old Mar 14, 2010 | 05:32 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Just got done with my 4th gen seat swap and thought I would share some pics. The job took about 8 hours with the seat belts included. It sure helped to search other peoples posts. 4th gen seats. It really is as easy as it sounds-march-10-040.jpg
Old Mar 14, 2010 | 05:36 PM
HankL69's Avatar
Engine: 5.0 / 350
Re: 4th gen seats. It really is as easy as it sounds
Here is a before and after of the rear seats.4th gen seats. It really is as easy as it sounds-march-10-042.jpg
Old Mar 14, 2010 | 05:45 PM
HankL69's Avatar
Engine: 5.0 / 350
The original seats were really not in bad shape but, to me, they never looked like they belonged in this car. If I had ordered this car new in '85 I would have ordered black seats. I do like the contrast of the charcoal leather with the tan carpet and trim . The new seats are out of an early 4th gen Firebird , or at least that is what I was told when I bought them from antoher TGO member. The whole swap went very smoothly, the only real issue was forgetting to put the belt retainers on . Overall, I'm very pleased with the end result.
Old Mar 14, 2010 | 05:49 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
looks good but you still have a contrast issue with the new ones but I would leave it the rest of your interior is in good shape, but the new seats will probably be more comfortable to say the least.
Old Mar 14, 2010 | 05:57 PM
HankL69's Avatar
Engine: 5.0 / 350
I like that contrast. The door panels are tan with black accents. The original interior had the black console with the tan carpet. To me it looks very classy. And yes, it is very comfortable.
Old Mar 15, 2010 | 06:39 PM
steNcho's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Is it hard to swap the seatbelt part inside the headliner?
Old Mar 15, 2010 | 06:49 PM
Stephen's Avatar
Car: 87 GTA
No real need to swap the seat belts, unless your original ones aren't working right anymore or are damaged. Every time I've put in 4th gen seats, I've just reused the OEM seat belts.
Old Mar 15, 2010 | 06:51 PM
HankL69's Avatar
Engine: 5.0 / 350
Some of the others who have done this say to remove the entire headliner but, since I have an over-head console that I really didn't want to remove, I decided to try just pulling it down from the back and reaching in to get at the bolts. It worked out just fine. I pulled the trim from over the door, sail panel and the piece that goes across the rear glass. The belt retainers are almost identical (3rd & 4th gen) and bolt right up with no problems.
Old Mar 15, 2010 | 06:55 PM
HankL69's Avatar
Engine: 5.0 / 350
I swapped belts to change the color. I didn't like the look of the dark seats with the tan belts. The nice thing about keeping your original belts is that you don't have any issues with the door sill plates . Anyone have any tan '83 f-body sill plates for sale???
Old Mar 16, 2010 | 04:34 AM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
They Look GREAT ! ! !
Old Mar 16, 2010 | 06:43 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
8 HOURS!!! someone works slow...
Old Mar 16, 2010 | 08:17 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
4th gen seats FTW. I liked mine so much, I bought another pair! lol
Old Mar 18, 2010 | 08:00 AM
HankL69's Avatar
Engine: 5.0 / 350
That time included shampooing the carpet and removing the new seats once because I forgot to install the belt retainers on the belts the first time. There was also a trip to the auto parts store for one trim fastener and a couple of cocktail breaks. Working too fast on a Saturday only leads to more work.
Old Mar 30, 2010 | 06:39 PM
BobbyRod's Avatar
Car: CAMARO RS 25th Anniversary Z03
Engine: L03 V8 5.0
Transmission: THM 700 R4
Axle/Gears: 2.73 OPEN
LUV my 4th gen LS1 seats! (Front)
No hassle at all!
Very comfortable, nice upgrade, A REAL BOLT-ON!!!
Old Mar 30, 2010 | 07:32 PM
bcmag's Avatar
are 4th gen belts and seats a direct swap or is there fab work involved?
Old Mar 30, 2010 | 07:38 PM
BobbyRod's Avatar
Engine: L03 V8 5.0
seats Yes! direct swap
Belts I did not do...
Old Mar 30, 2010 | 07:43 PM
HankL69's Avatar
Engine: 5.0 / 350
Like the post says It really is as easy as it sounds. Take the old seats out, put the new ones in. The only real issue is the lower seatbelt mount is different . There is no lower recoil on the 4th gen belts so the notch in the sill trim is visible. If you search the site you will see how others have solved the problem. One way is to use '82 sill plates.
Old Apr 3, 2010 | 02:09 AM
Robb Knight's Avatar
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
I have never removed a seat of any type on a car. So So everything underneath or whatever connects and lines up? You just take out the 3rd gen seats and put in the 4th gen with out changing any mounting or whatever? They attach the same way and same points?
Old Apr 3, 2010 | 04:28 AM
joee5's Avatar
Car: 1986 Z28, 2006 Cadillac Escalade
Engine: 5.0 litre
eventually i'm going to swap out my red interior for gray on my 86 z28. i have thr plastics as well as the carpet and am shopping for seats. i didnt know that no mods were needed to make the 4th gen seats work. thanks for posting this and sharing with those of us that arent as well mechanically inclinded as others. myself included.
Old Apr 3, 2010 | 07:54 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
You cannot ever knock someone for wanting to do a quality job over simply getting it done for the sake of getting it done. Attention to detail is what makes it all worth while.
Old Apr 3, 2010 | 10:02 AM
Stephen's Avatar
Car: 87 GTA
Yes. 4 nuts hold each seat onto studs in the floor. And 2 screws hold the seatbelt retainer to the seat.
8 nuts & 4 screws total, will swap seats out.
Only modding you'd need to do, is if your putting electric seats in. Then that would just require some wire splicing.
Old Apr 4, 2010 | 06:26 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Werd. Looks good man, those seats are in great shape. Putting 4th gen leather in my iroc was probably one of the best things I've ever done to it. I get lots of compliments and they are just wicked comfortable.
Will
Old Apr 4, 2010 | 07:56 PM
BobbyRod's Avatar
Engine: L03 V8 5.0
Originally Posted by norcalz28
.... and they are just wicked comfortable.
NOTHIN' MORE RIGHTY!!!
Old Apr 12, 2010 | 08:24 PM
vengetta82's Avatar
Car: 1982 Camaro Berlinetta
Engine: LG4
Transmission: One that shifts hella hard
what about power seats?
Old Apr 12, 2010 | 11:30 PM
BobbyRod's Avatar
Engine: L03 V8 5.0
I just ran a poistive wire from fuse box (power lock circuit) and a ground and that's it, works just fine.
Old Apr 13, 2010 | 01:17 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
It would have been a quicker way than how I did it. I went to the bone yard and scavanged a complete wiring harness pulled the carpet up and ran it so it looks factory.
Old Apr 15, 2010 | 01:59 AM
BobbyRod's Avatar
Engine: L03 V8 5.0
Yeah Sure! I took the power from the power lock circuit because There's where the stock circuit is taken according to Chilton's manual.
So it looks stock too! ...Anyway here in Venezuela we have not as much choices as in the US!!!
Old Apr 21, 2010 | 12:56 PM
NBC's Avatar
NBC
How hard are the back seats
Old Apr 21, 2010 | 01:14 PM
Stephen's Avatar
Car: 87 GTA
Even easier, since there is never a possibility of an electrical connection there. Just a few nuts.
Old Apr 21, 2010 | 01:42 PM
norcalz28's Avatar
Well, if your car was like mine and had split rear seats, that bar that secures the inner edge of the seats will look dumb if not used. I just removed it, no biggie, but it may be something you'll run into.
Old Apr 21, 2010 | 02:31 PM
Stephen's Avatar
Car: 87 GTA
I left my split rears in & only put in 4th gen front seats.
Old Apr 21, 2010 | 11:39 PM
BobbyRod's Avatar
Engine: L03 V8 5.0
I did the same thing
Old Apr 25, 2010 | 02:29 AM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
Bump to this thread..
These look great! How much did the new seats cost you? I want to do the exact same thing to my 90' RS. I'm changing my interior from gray to black, and have the carpet down already..I just need to get some new black leather seats, but I can't find any sources to purchase them from. Any help will be greatly appreciated
Old Apr 25, 2010 | 09:38 AM
jstoltz's Avatar
just get some fourth gen seats and get new covers not the cheapest but they look brand new when your finished.
Old Apr 25, 2010 | 10:23 AM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
Seats look good... but the contrast is horrible. Maybe get some covers or something? The originals were buck ugly man, better choice overall.
Old Apr 25, 2010 | 10:43 AM
HankL69's Avatar
Engine: 5.0 / 350
The seats I used were from fellow TGO member RCAR7395. I thought his price was vewry reasonable. I know that he has listed several other seat sets on this forum since. Check him out, maybe he can help. He sure was easy to work with.
Old Apr 25, 2010 | 12:43 PM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
I sent him a pm but he doesn't have any more black leather seat sets at the moment..oh well, I'll just have to keep looking around. Do you think going to a salvage yard might be a good idea?
Old Apr 25, 2010 | 12:47 PM
jstoltz's Avatar
worth a try but being in Texas they might be a little sun baked though.
Old Apr 25, 2010 | 12:55 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Took me all of... 45 minutes I think to do mine. But I reused my belts and such.
It's amazing how much mroe headroom I got afterwards. There is a LOT more room in the back. I am 6'2 205 lbs and I could handle sitting in the back on a short trip now, whereas before I couldnt fit back there at all.
Old Apr 25, 2010 | 01:04 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
it should be possible to get a good set of cloth 4th gen seats for $100-$150
Old Apr 25, 2010 | 01:10 PM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
What about a leather set?
Old May 26, 2010 | 02:33 PM
  #42
modern0utlaw's Avatar
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
Leather sets are around 500-800 on ebay. I scored a dark gray cloth set from a 97 camaro for just $50 on craigslist, they were taken out when the car was new and never used. So it just depends if your lucky enough to come across a good deal
Old Jun 24, 2010 | 12:09 AM
  #43
topgun91's Avatar
Car: 1991 z28
Engine: lt1 swap in process
Axle/Gears: posi 3.23
are seats from a 02 camaro a direct bolt on for a 91 rs
Old Jun 24, 2010 | 12:21 AM
  #44
Stephen's Avatar
Car: 87 GTA
ALL 1982-2002 seats are a 100% physical bolt in swap. The only time you'll have any swap issues, are with wiring for power seats. Even then it is just a matter of splicing wires (if you already have some, or running new ones).
Old Jun 24, 2010 | 12:22 AM
  #45
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
nope, the originals matched a lot better of course. and these seats aren't even black.
Old Jun 24, 2010 | 12:24 AM
  #46
Stephen's Avatar
Car: 87 GTA
Huh? Are you trying to say that I was wrong?
Old Jun 24, 2010 | 12:26 AM
  #47
92 Camaro's Avatar
HAH?
Old Jun 24, 2010 | 12:32 AM
  #48
Stephen's Avatar
Car: 87 GTA
HAH?
Somebody drunk & posting tonight? You aren't making a lick of sense with your posts tonight!
Old Jun 30, 2010 | 12:07 PM
  #49
navy02ws6's Avatar
Engine: LS1, LB9, L03
Those are 1997-02 Camaro seats. All Firebird seats have actual adjustable headrests.
Old Jul 1, 2010 | 07:36 PM
  #50
HankL69's Avatar
Engine: 5.0 / 350
I realize that now. Since I installed the seats I have been checking out what's in a lot of 4th gens. Still love 'em! Haven't used the car much lately though, weather has been so nice the 'vert is getting all the miles.
