How Do I Remove Old Dash? (The WHOLE Thing!)
Old Apr 14, 2010 | 06:35 PM
camarobuff1's Avatar
Car: 1992 Z28 Z03
Transmission: AT
Axle/Gears: 3:73
Hey I'm pulling out my cracked dashboard (not just the top) and replacing it with a nicer one from low mileage IROC. Anything I should know in pulling out the whole thing? -Tricky stuff - Steering Shaft, etc. Or is it pretty straight forward, just a bunch of bolts?
Thanks!
Camarobuff1
Old Apr 14, 2010 | 06:48 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: How Do I Remove Old Dash? (The WHOLE Thing!)
Lots of wiring, lots of bolts, lots of time. Its easier without the windshield in the car as well. You don't have to touch the steering column if I recall correctly.
Old Apr 14, 2010 | 06:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
remove the dash pad, and on each corner of the shell, you will see one big bolt, and under the shell pointing straight up is two more big bolts, those are the four MAIN bolts that attach the shell to the body, and then of coarse with the dash board removed, you need to remove a whole lotta 10mm bolts in various locations to remove the ac ducting and other junk.
and drop the steering column to make overall removal easier.
Old Apr 16, 2010 | 11:38 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I just recently got mine all back together. It took me several hours to get it apart, and a few more hours than that to get it all back together, but I did a good, thorough job. It is pretty straight forward, just removing bolts and nuts. Take your time and find all the bolts. It comes apart easily as long as you find all the bolts and nuts holding it on. While you have everything apart replace the heater core. They don't cost much and if yours is old it probably will start leaking before too long. I also replaced all the old foam gasketing on the a/c vents and stuff and sealed everything up good so there aren't any leaks in the vent system. Autozone has foam in various sizes, Wal-Mart and Home Depot has it too.
Use masking tape and a pen to label every single wire you disconnect so you can remember where everything goes later. Do this as you go so you don't forget one. Sort screws, bolts, and nuts in zip-lock bags and label them "left side", "right side", "lower dash", or whatever. You will probably have no idea where all the bolts have disappeared to and where they go back in if you don't do this. The steering column is real easy to lower, just two nuts holding it up from underneath.
Old Apr 25, 2010 | 04:15 PM
Code1racing's Avatar
Car: 1989 Rs
Engine: 355
Axle/Gears: 3.42 Gear
I am having trouble getting mines to seat properly, I have 2 of them one from an 86 model and the other from an 89 the 89 is cracked badly because the previous owner of the car tried to remove it also. would you have any further advice
Old Sep 23, 2010 | 08:14 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Is there a detailed write up with pics on dash board removal?
Vintageracer
Jan 10, 2020 05:33 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Street Lethal
Aug 14, 2015 08:25 PM
Vintageracer
Aug 11, 2015 08:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
