Rear Pull Down Motor differences by year?
Old Apr 20, 2010 | 07:07 PM
Bigpenguin182's Avatar
Car: 1990 Firebird Formula
I've seen several threads on this problem but nobody with the exact same issue..
I had my rear trunk motor burn out, checked fuses etc. I ordered the same rear trunk motor with plastic housing that you find at topdownsolutions.
The new motor and housing bolt on correctly (as in it attaches to the pull down motor) but the black plastic contact (attached to the larger pull down mechanism) and the contact on the motor (on the clear plastic part) for the electrical attachment don't match up. It seems like it is obviously a difference in the physical design of the factory pull down assembly.
Basically the original motor and plastic housing is different from the replacement motors and housing that I am only able to find.
Has anybody else encountered this issue? I have a 90 firebird (built in August of 89), the entire assembly looks exactly like every other i've seen except for this small difference. Is my only option to replace the entire pull down assembly?
Old Apr 24, 2010 | 08:43 PM
Mudskunk's Avatar
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
Re: Rear Pull Down Motor differences by year?
might try some of the pick and pull places that specialize in third gens. firebird city and thirdgen ranch for a couple. i like to check my local gm dealer first. some parts are available some arent. i prefer oem before i try aftermarket or used parts.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 26, 2015 04:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
