helpp check this out any idas what this is
Old Jun 4, 2010 | 01:28 PM
jake1992jake's Avatar
Car: 1989 camaro rs
Engine: 406 chevy
Transmission: turbo 350
Axle/Gears: 3:73 posi
help me find out what this isshelpp  check this out   any idas what this is-jkkkkkddd.jpg
helpp  check this out   any idas what this is-jkkkkkkkkkkeeeeeeeeeeeeeeeeeeeeee.jpg
Old Jun 4, 2010 | 03:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: helpp check this out any idas what this is
That looks like the shifter cable - is this an automatic?
Old Jun 4, 2010 | 03:03 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Not the shifter cable.
Its the shifter lock-out cable.
Prevents you from moving the shifter if the key isn't on.
Old Jun 4, 2010 | 03:45 PM
Car: 1989 camaro rs
Engine: 406 chevy
hey thanks so if im putting a th350 a carb swpp what do i do with it then??/
Old Jun 4, 2010 | 04:08 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You can tie it back with wire to keep it extended. If I remember right it also keeps you from locking the ignition without the shifter in park.
Old Jun 4, 2010 | 04:25 PM
Car: 1989 camaro rs
Engine: 406 chevy
yea it does so u tie it out
Old Jun 4, 2010 | 04:30 PM
No need at all to "Tie it out". If it is already unhooked from the shifter than it isnt doing anything at all. Either remove it, or tuck it under the dash or console and forget about it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Numbah-1
Sep 12, 2015 08:57 PM
