cigarette lighter/85 firebird
Old Jul 13, 2010 | 10:36 PM
ajfirebird1985's Avatar
Car: 1985 Pontiac FireBird T-Top
Engine: 305 V8 5.0
Transmission: AUTO
Axle/Gears: Posi Rear-End 3.8
how do you change/replace a cigarette lighter in a 1985 pontiac firebird...where does it unhook at? how do you get it out and hook a new one up? also my dome light is not working could this all be related to a fuse? since they are both out a the same time?
thanks
Old Jul 13, 2010 | 11:05 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: cigarette lighter/85 firebird
Yes it's a yellow 20 fuse, think the name starts with a C
Old Jul 13, 2010 | 11:07 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Thats the "ACC" fuse.
Old Jul 15, 2010 | 05:17 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I had problems with the lighters in both of my Camaros, so I gutted them, JB welded them together, and replaced the fuse that blew for the last time.
Old Jul 17, 2010 | 08:35 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
... He means the CTSY fuse... Will be just to the right of the frontmost circuit breaker, a 20A fuse, as is previously mentioned. Also controls the radio ignition power.
The lighter is easy to remove. Open the console arm rest and the ash tray cover. Remove the ash tray. Remove the screw underneath, the 2 screws at the end of the shift plate that sits under the arm rest, and the shift ****. Lift the plate gently, unhook the compartment light (if you have one), the shift indicator light, and the 2 connectors from the lighter. Unscrew the base of the lighter from the plate, and pull the rest out the top.
jtwoods4
Sep 3, 2015 05:39 PM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Moore89
Aug 24, 2015 07:06 PM
