how to take door panel off?!?!?!?!?!?
Car: 89 RS convertible, 82 MSE Trans Am
Engine: 305-305
sounds easy... but i need to take it off of a pair of doors that have power windows..... the doors are off the car and the windows are up, how do i get the upper trim off with out breaking the window?
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: how to take door panel off?!?!?!?!?!?
If you gently pry the bottom of the panel you can pull the panel once you get the bottom loose work your way up the sides there is a 50% chance of breaking clips but they are easy to find i believe i payed about 45 cents a clip last week when i did mine
Engine: 305-305
i got that far, but the problem is the top part with the weather stripping(inner and outer) i cant put the window down, so can i get the top off with out breaking the glass?
thanks for the response though!
Car: Soon t/b '84,'87 or '90camaro
Engine: 305,350, & 383 stroker
Transmission: 700R4 & T350
Axle/Gears: 373
Removing and replacing door skins!
Has anyone ever done this? How much work would that entitle??? I know Eastwood sells the door skin pliers but...
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Removing and replacing door skins!
I'd put 12v to the window motors from a battery and lower the glass - I'm sure it could be done with the widows up, but would be alot easier with them down.
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
that what i do just put some leads on my battery charger and hook them up to where the wires hook up to the motor
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
