Stem On Manual Mirror Dr. Side-92 RS
Old Jul 31, 2010 | 11:27 AM
ty1on2's Avatar
Car: 92 Camaro RS
Axle/Gears: stock
Hello to all, I have a problem with the Driver Side manual mirror.
The little Stem that you use to adjust the mirror is eather broke or
it has fallen out. It does not look like that there is anything down in
the hole where it goes in. Any help would apprecited. TY ALL
Old Jul 31, 2010 | 11:52 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Stem On Manual Mirror Dr. Side-92 RS
It may have broken and follen down into the door. You'll need to take the door handle cover plate off and see if you see it in there. It ataches to the mirror permanently as far as I've ever seen, so if it doesn't look fixable, you'll need to get another mirror and swap the guts to your mirror housing (so you can keep your color-matching housing).
Old Jul 31, 2010 | 12:23 PM
ty1on2's Avatar
Car: 92 Camaro RS
Axle/Gears: stock
Thank you Camaronewbie, I have the door panel off right now and I dont see it.
Man just had the car painted, now have to find another mirror. Thanks again.
Old Jul 31, 2010 | 01:01 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Like Camaronewbie said theres no need to swap the mirror housing, just swap all the guts from the new mirror into your already painted mirror housing.
Old Jul 31, 2010 | 02:47 PM
ty1on2's Avatar
Car: 92 Camaro RS
Axle/Gears: stock
Ok then, what is involved in taking my guts out and installing new ones?
Old Jul 31, 2010 | 03:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I think there is a flex cable attached to the lever.Try looking for the cable too.The mirror itself is held on by three screw inside the housing.Just angle the mirror to its max & undo them.
Old Aug 1, 2010 | 12:48 PM
ty1on2's Avatar
Car: 92 Camaro RS
Axle/Gears: stock
Thank you all for posting your advice, now all I have to do is find a mirror,lol
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
