HELP
HELP
Just bought dimming mirror with temp and comp.
I'm having a hard time getting the wires from the mirror
down the A pillar to the fuse block and the wires for the temp
sensor up the A pillar to the mirror. what am I doing wrong?????
ANY AND ALL HELP NEEDED THANKS
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: HELP
Removing the pillar without breaking the mounting points and/or the retaining clips will be an adventure. Check late in the following link for pics that may be helpful:
https://www.thirdgen.org/forums/body...servation.html
JamesC
JamesC
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: HELP
Oh definitely - they always break - but given how far into the windshield they go, I'm not sure one could successfully fish wires through there without removing it. Might try a metal coat hanger and work it in there - removing the dash pad wouldn't hurt.
The clips are still available at the dealer if you remove the pillar and they do break, but they are $20 for a set.
