Where would this go?
Old Sep 26, 2010 | 11:02 AM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
The red line points out the vacuum like type hose under the dash.
Old Sep 26, 2010 | 11:52 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Where would this go?
There are 2 vacuum lines inside the cabin - they are for the heater controls. The vent selection is vacuum controlled. A line comes in to the controls, and a line runs out to the heater diverter valve. Not all cars had the heater diverter valve. This valve is under the hood, has 3 heater hoses to it and a vacuum line - when set to WARM, the diverter valve opens and allows warm coolant to run through the heater core, when set to COOL it closes in an attempt to keep the cabin temps cooler by not letting the hot coolant into the heater core.
Both of the vacuum lines will enter the firewall just at the bottom driver side corner of the heater box, in the bundle of wires that control the heater blower motor.
Old Sep 26, 2010 | 11:55 AM
roc in chair's Avatar
Car: 86IROC,85Z28,70 Chevelle,92 Mustang
Engine: 305,305,350,5.0
Transmission: 700 R, 350,5-Speed
If if have cruise control. It might be for the cruise control vacuum brake switch. Mounted next to brake light switch.
Old Sep 26, 2010 | 11:59 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Thats what I was thinking since it seems to be headed in that direction.
Old Sep 26, 2010 | 12:12 PM
Car: 1992 RS
Engine: Carbed 350
didn't think of that - don't think my 1992 has any vacuum CC lines, think it's all electronic - I've never seen any vacuum lines at the brake pedal.
Old Nov 2, 2010 | 09:07 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
What was the verdict. Heat or CC
