Moving window switches to the armrests or door panel?
Old Sep 29, 2010 | 09:24 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Has anyone thought about or actually done this?
Old Sep 29, 2010 | 10:04 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Moving window switches to the armrests or door panel?
The guys with 4th gen door panels have done it...I THINK...
Either way, it would be very simple to do. You would just need to move the window switch harness and split it so that each side runs to its respective side of the car. Then you'll have to extend all of the wires, probably running them under the carpet, then up into the kickpanel area, through the door jamb, and into the door.
From there, you'll either need to fit the stock switches, or get a switch from another car that you like. You should be able to wire any switch to work fairly simply.
Probably the hardest part will be mounting the switch in the door and running the wires so they dont interfere with anything. Still...not a hard job I dont think.
Justin
Old Sep 29, 2010 | 12:28 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The wiring is different when you've got the switches in the doors, though I imagine that you could just parallel-wire the two switches for the passenger window. Maybe somebody can chime in with a pic of a 4th gen wiring diagram.
Old Sep 29, 2010 | 01:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i think it's a great idea , to have them in both locations and working would be even better . IMO . i have aftermarket power windows (spal) in my present ride so my wire hook-up would be different . BUT , a great idea . i'm going to start looking for some switches . great idea , good luck .
Old Sep 29, 2010 | 03:56 PM
UNCLE TOM's Avatar
well i just ordered a kit from SPAL . they sell kit #33940018 that will work for me . switches look a lot like original , nice looking harness & connections , good diagram that will work (for almost all) , i know will work for me . $33.81 shipped . hope to have them installed by "Cruisin the Coast" . plan on installing my switches just fwd. of door open lever . my camaro is a base model so that panel is open . ck. them out they have several kits that may work for you . good luck .
Old Sep 30, 2010 | 06:37 AM
Car: 86 Trans AM
Ah yes... I forgot that you'd be putting controls for both windows in the drivers door... Tho our cars arent very big inside so reaching over isnt that hard haha.
Wiring in the extra switch would be pretty easy. You could probably reference some 4th gen wiring diagrams, or some other cars...like maybe a monte carlo from the same year. Wouldnt be difficult to figure it out.
OP...are you doing something custom with the center console? Or just want the switches in the doors for the heck of it or what? Just curious.
J.
Old Oct 1, 2010 | 08:07 PM
UNCLE TOM's Avatar
i plan on hooking my door switches hot with out key on . i have console switches that work with key on only . i want one on each door so it's easy for riders . why hot all the time you ask . i live in the S.E. part of our country and rain pops up in a heartbeat . i am a retired acft. mech. and i will hook them (fused) correct . they will work from both the console and door . good luck .
Old Oct 2, 2010 | 10:34 AM
92z28rockinmaro's Avatar
in my 3rd gen z28 the previouse owner had i believe a 96 or 97 console in it with the window switches are in the console where the ash trey would be.. its pretty stealthy.. lol will get picks up soon
Old Oct 3, 2010 | 09:08 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
4th gen window switch wiring attached. Note that if you are not using the "express down" module, run a wire from pin E on the driver's window switch directly to pin A on the drivers side motor.
File Type: pdf
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
