4th gen console wiring
Old Nov 9, 2010 | 05:35 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Transmission: Borg Warner T-5
Axle/Gears: Borg Warner 9 bolt - 3.70 posi
Want to do a 4th gen console swap. does anyone know if the harness for the window and mirror switches will reach to the front wall of the storage compartment?
Old Nov 9, 2010 | 06:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 4th gen console wiring
It's simple wiring, not hard to extend them if needed.
GM is not famous for giving extra wiring. Extra long bolts where you don't need them are abundant, but wiring is as short as possible!
Old Nov 9, 2010 | 06:26 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
yeah, that sounds about right. unfortunately, still need the ashtray or i'd use that space. Also looking to do something I haven't seen on here a thousand times.
Old Nov 9, 2010 | 07:18 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Even if the wiring was long enough, there simply isn't enough depth anywhere in the actual glovebox portion of the 4thgen console that will accommodate the switch and the wiring on it... been there, tried that.
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
