How to take seats apart
Old Nov 17, 2010 | 06:21 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Ok I bought some 4th gen seats from a junkyard and they arnt in great shape but I am going to re cover them anyways My question is how do I remove the uphostlry and how do I separate the seat pan from the back of the seat there is some rust on the seat pain and I need to fix it before I recover them I saw a bolt on the side that looks like a hex pattern in it the only tool I have that will fit in it is a large allen wrench but it wont turn it. Then the other side has the adjustment mechanism and I dont know how to remove it. Please Help if you can.
Old Jan 30, 2011 | 07:49 AM
Camatruder's Avatar
Car: 88 Camaro V6
Re: How to take seats apart
I want to re cover my 3th gen seats, and have the same question.
I have the right tools but don't want to start unknowing.
Anybody?
Old Jan 30, 2011 | 11:55 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I want to recover my 3rd gen seats also but would like to hear from someone whos done it first.
Old Jan 30, 2011 | 11:08 PM
coastiematt's Avatar
there's 4 main bolts that hold the slider to the bottom of the seat. you need to remove those... if you have an electric seat, make it easier by adding w/ wire nuts an expansion for the power so you can manipulate your seats out of the car while removing these bolts. (that's what I did)
Once you have the bolts off and the sliders, undo the plastic side housing, after that it's all just pretty simple. I think the seat covers for the bottoms are just "clips".
The seat cover for the stop should come off while working it out. it's held together by some velcro underneath.
hope that helps-
Matt
Old Jan 31, 2011 | 07:34 AM
torque_is_good's Avatar
I did it before Christmas. I actually have a restore thread on another forum (camaroforums)
Anyway, there are hog rings holding on the old covering. A screwdriver and slip joint pliers/needle nose will remove them. There are lots of them.
There are also metal rods that are attached by hog rings on one end that run throught the middle and sides iof the covering in the seating area. Frankly, since you are replacing the covering, use a utility knife and just cut the cloth tabs (it's obvious) and you can go back later and remove the rest.
As for the metal backing, I used a wheel and removed the visible rust and then used some Rustoleum rust reformer for a protective coat. I did this with the metal still on the seats. I also did the same with the seat rails.
When reinstalling, I used tie wraps to attach the covering
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
