Post pics of 4th gen leather seats in 3rd gen
I'm debating on putting the Ebony leather seats out of a 98-02 in my car. The only thing I'm not sure about is the color. My carpet and everything is solid black. The 4th gen seats have more of a grey color to them right? Post up some pics I want to see what they look like!
Engine: LS1, LB9, L03
Re: Post pics of 4th gen leather seats in 3rd gen
Yes, the later 4th gen Ebony seats are DEFINITELY not black as the name implies. Ebony is basically a dark charcoal color, but the closest thing you could get to black from 98-02.
If you've got a black interior in your 3rd gen, Ebony seats would not be a 100% match. Nonetheless, it's probably still your best option for seats, unless you can source some nice Black leather 94-96 seats -- those are significantly harder to find though.
Car: 1992 Camaro RS
Engine: 355
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
perhaps score some 93-96 cloth seats for cheap, then throw on replacement black leather seat covers?
http://www.hawksthirdgenparts.com/ca...atherlike.aspx
I don't know why they're calling it ebony, my buddy has a 95z28 and his leather seats are straight BLACK.
Contact some of the suppliers of recovering kits and ask for a sample of their leather or ultraleather material. Most should be fine sending you a swatch...
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Car: 91 z28
Axle/Gears: 345
ok the other two switches are for my fans. i put in 4th gen dual fans and a flexalite controller. the switches control all off or all on.
the seats are from a 1998 camaro.
the steering wheel is from a 2000 camaro i believe.
and the little light in the middle of the other two switches tells me when the fans are on.
Car: 1987 Iroc-Z
Engine: SD360 350 Vortec
Do these 4th gen seats bolt right up to 3rd gens? Sorry if this is a dumb question...
Car: 1987 Iroc-Z
The rear seats too? If so do they fold down and function just as the 3rd gens do? Thanks again and sorry for bothering you...
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I think they are but not sure probably someone on here will tell you sorry
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Yes, both front and rear seats bolt in and operate the same. Here's mine:
Car: 92' RS
Engine: LT1 from a 94 Ram Air
Transmission: Beefed 700R4
Anyone have an idea on an avg. price for a decent set of 4th gen seats?
i put in 4th gen front and rear seats. had to cut the bar that was there for the 3rd gen seats. other than that they work great and fold down.
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
i was wondering if you dont have power front seats and you get power front seats how do you hook it up to the track and things like that, or do i have to find a manual set. and the whole set is direct bolt in right? so like any seat from a 1982-2002 camaro/firebird will work?
Car: 1987 Trans Am
Engine: 5.0L
Transmission: Manual
Car: 84 T/A, 87 iroc-z, 86 turbo z-28.
Engine: 5.7, 5.7, 6.6
Transmission: t-5, 700r4,manual shift th350
Axle/Gears: 3.73, 3.52, 3.23
17 bucks for the front pair here in spokane
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
I have 91 RS with a black interior what years have the most black leather seats?
Car: 82,83,99 T/As
Engine: 350,350,383
A little question that I haven't found the answer to with a search.
Will the six-way power (front, back, tilt front up/down, tilt back up/down) tracks, from a 4thgen work on 3rdgen seats in a 3rdgen? I want to keep my seats and would like to make them power. I know that it's just 4 bolts and run a power wire. But what about the side plastic cover molding?
Car: lots of Firebirds!
Engine: LS1s, 455
Transmission: t56s all around! lol
[quote=navy02ws6;4793943]Yes, the later 4th gen Ebony seats are DEFINITELY not black as the name implies. Ebony is basically a dark charcoal color, but the closest thing you could get to black from 98-02.
quote]
I don't know about Camaro seats but I just figured I'd mention 00-02 TA seats are more of a black than the 98-99 seats. My 89 GTA has black leather seats and the seats in my 01 TA are just as dark. I have a wrecked 00 also that's going to be the donor for my LS1 swap into the GTA, it's seats are the same darker color as the 01.
quote]
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Be careful when buying seat covers. I got these from an aftermarket company whose name escapes me now, they were supposed to be black. Fail.
1992 Trans Am
May 10, 2023 07:19 PM
drathaar907
Aug 10, 2015 07:44 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
